RCU Forums - View Single Post - Yellow P47 Build up
Old 12-02-2004 | 03:43 PM
  #122
heliraptor
Default RE: Yellow P47 Build up
Hi Dan
Here you go, took some in between glassing.
Pictures show in order
1. Aileron fitted as it would be on the finished model, blue marker pen is the hinge line.
2. Close up showing the grooves are hidden by the TE strip.
3. Aileron shown on full deflection (5/8" manual recommends 3/8 in flight) grooves show a little but this will be in flight remember.
4. Aileron pulled out to show the grooves and hinges.
Hope it helps.
Lee
ID:	198678   Click image for larger version
ID:	198679   Click image for larger version
ID:	198680   Click image for larger version
