RCU Forums - View Single Post - Pitch Issues
Thread: Pitch Issues
Old 12-13-2001 | 03:41 AM
HeliDriver
Default Pitch Issues
Hi volare,
This is the setup I run on my rappy, -4 +6 +10 with a head speed of about 1550rpm at hovor. Your throttle curve at this point is based on your pitch at hover, so if you want more neg pitch then all you will need is to reajust your atv's. This shouldn't change your curve because the servo still knows where center is and the curve is based on center for hover. I was able to get this set up with my atv's and the manual setup in combo. by using center stick as a hovor point, I can also change it with my pitch curve and my hovor pitch settings in my radio.
Your rpm's will rise when you come down in pitch due to the lack of load on the engine and at this point shouldn't be a concern unless the head speed in at an uneceptable rate, in fact for myself the higher head speed is benificial because it raises the ETL (efective transational lift) with forward movment.
When you set up your idle-up the rpm's will raise for the same reasons as above with one diferance, the idle-up is set up with a percentage of throttle thus 50% meaning the servo will travle to 50% and hold it there when the throttle stick is moved down past center but the rpm's will still be based on what ever you have for a throttle curve at min stick. My idle-up is at 47% and my throttle curve on idle-up1 is 45-45-47-75-100. The best thing to do is set up your idle-up and find that happy medium that makes you comfortable. Your rpm's should be around 1500 to 1600 at hover and will raise a little when you come down in pitch and you can use your throttle curve in idle-up to achieve the rpm's you want. The way I was able to control some of the raise in rpm's was to drop the first two points on my curve to 45%. When I start doing some iverted flying this setup will change.
Someone please help me out here in case I've got the wrong idea about curves.
Hope some of this helps.
Heli on,
Shannon
