revised JPO proposal
Steve - looks pretty good !
I think Scott has a valid question about the aircraft type used for the solo demonstration. When I read the proposal, I assumed that it meant that a turbine powered aircraft could be used - but since it doesn't actually state that (and the old rules specifically prohibited use of a turbine aircraft for sign-off flights), it might prevent some confusion if that point was made explicit.
BTW - glad to see that the proposal includes provisions for turbine powered aircraft that won't do 150 mph.
Good work - thank you !
Gordon
