RE: Yellow P47 Build up
Lee
I had interpreted the set up differently. I thought the leading edge had to be opened all the way back to the hinge line as that was where the hinge pin would be and it would have to be open to allow travel. By your pictures it appears you got the hinge pins back near the hinge line but did not open the leading edge very much. Is that correct?
