RE: ZDZ 40RE Powered Impact
according to my calculations if you put an 8411sa in tail under stab with direct link 4' long or so this will offset the engine weight, everything else should go in according to instructions. there will be some additional balance adjusting capability w. ignition batt. this setup will keep rudder servo and cables out of the way so you can switch out large pipes through the canopy no problem during contests.
