RE: BME Ultimate and DA100
Brian,
It will not be good. In order to get the power out of the DA 100, you are going to have to prop it for high rpm. Then you are going to have noise issues. Holden had his Da 100 in a 28 lb plane and it struggle on up lines in our heat. then he switched to a smaller prop and then it made to much noise.
