RCU Forums - View Single Post - GP Super Stearman
Old 12-04-2004 | 12:22 PM
  #177
leegscott
Default RE: GP Super Stearman
Bigbird3 your plane looks great.
I received my super stearman earlier in the week. I am going to start putting it together next weekend. I have to finish a Funtana 90 this weekend. I was planning to put a Saito 180 in the stearman. I was wanting to put in a slimline pro super smoker, however, I do no know where I will put the tank. On past projects, I have placed the fuel tank on the CG and the smoke tank up front. Judging from the instruction manual it looks like the stock location of the center of the tank is already close to the CG. I was also thinking about installing dual elevator servos with separate push rods. In addition if there was room, I was thinking about installing a pull pull rudder. What are you thoughts? Or do you think I am just doing a lot of extra work that will probably not make any difference? Not to consider adding weight!!!
Thanks for anyones thoughts!
It looks like there has been a lot of discussion about this plane. However, if anyone is interested I will post pics of any of the construction process if requested.
