RCU Forums - View Single Post - Anybody know how to do a rolling circle?
Old 12-04-2004 | 08:19 PM
Bob101
Default RE: Anybody know how to do a rolling circle?
I do mine backwards from most people. Instead of making the "circle" turn part using the elevator when the wings are perpinduclar to the ground - I use the rudder while the plane is inverted and upright.
Just started out that way to learn it. After you get that down and it's rough, but a true rolling circle then you start blending all the controls together as you go around so that it smooths out.
Have a plane that's set up good to begin with, if it's nose heavy getting a good rolling circle is very hard because the nose wants to drop bad while inverted and that's just one more thing to deal with.
