RE: Pull Pull Servo Connections
My 2 cents.... I don't trust EZ connectors. I make my pull pull out of nylon coated leader wire from the fishing store, use 1/16" ID copper tubing, and those 2-56 studs with the holes in the end. That is my control surface solution. I simply make a loop at the servo end and go thru the servo arm. (Adjustments made at control horn end) You make the loop with the wire and pass it back thru the tube after going thru the servo. Then you take the wire and fold over the top of the tube and pass thru the tube again, then crimp a couple times. It will NEVER let go. For a really detailed explanation, see an old control line flyer. They know how to make secure wire connections!
