RE: Capiche 140
Ok
If your favorite plane is a weston UK magnum use the 17x8 APC
If your favorite plane is the weston UK magnum and hype 3D use the 17X8N
If your favorite plane is the capiche 140 use the J'en 18x6
The J'en prop is much better. The prop gives you much more speed control and power control in both downlines and uplines, and the slower flight gives you a lot more time to get your onputs right. I wont be going back to the apc on this plane.
Unfortunately though for the 2nd flight of the day i screwed up my engine by mucking around with the needles and changing fuels. Got a deadstick and flew through a sapling, just mssing a drainage ditch. Luckily there wasnt much damage. Cant be arsed to bother with it anymore so im going for a more powerful engine
