Name: Two stroke model airplane gasoline engine
The volume of cylinder: 45.cc
Journeys of 0cc bore : 43MM *31MM (the cylinder and ZENOAH G450PU are in common use )
Carburetor : Walbro(membrane type double stitch carburetors of vacuum pump)
Exert oneself at most specially: 4. 2ps/9500rmp
Practical rotational speed: 1600-7800rpm
Weight: About 1650g
The way of light : CDI battery lights a fire (the voltage 6V of battery)
The proportion of the lubricating oil : 25-40:1
Use the spiral thick liquid: More than 20*10
