RCU Forums - View Single Post - GP Super Stearman
Old 12-05-2004 | 02:43 PM
  #180
leegscott
Default RE: GP Super Stearman
Bigbird
Thanks for your advise!! I have decided not to go with the pull pull rudder. However, I am still considering install dual elevator servos. In regards to the smoke tank behind the fuel tank. I think I should balance the plane with the smoke tank full as it will be behind the CG so that the plane will become more nose heavy as the oil is used. But, with that said it will require me to always have smoke oil in the tank even if I am not planning to make smoke during a flight. Do you agree? By the way that is a very impressive project you have under way. Will you be the pilot?
Lee
