RE: Starting first twin
I'm still building but have pretty much as far as I can without the landing gear and its back ordered. Anyone know if there is a problem getting the B&D gear?
Anyway, tail feathers are built. Rudder is about 1 inch longer and taller than stock. Still very impressed with the quality of the wood, but the trailing edge bevelled stock was too short. Someone mentioned a lot of sanding and no $%##@&^% Nacelles are framed but cant finish until their on the wing and dont wanna sheet the wing until the gear is in.
Hey muucksmear, Re your last, the photo seems to show the trailing edge 'notched' to fit the fuse. Thats different from mine. Anyway, the wing bolts are right where the servo will have to go, but I would like to use one servo for flaps instead of separate ones on each wing. The servo for ailerons and throttle out in the wing is enough weight out there already. Any ideas?
