RCU Forums - View Single Post - The value vs tradeoff of hinge tape?
Old 12-06-2004 | 09:51 AM
CRFlyer's Avatar
CRFlyer
Default RE: The value vs tradeoff of hinge tape?
An easy way to eliminate the tape, but still seal the gaps is to use an iron on hinge. There used to be a commercial product available, but it is not available any more. However, you can easily make a hinge using fabric covering. This type of hinge is invisible, as it goes under your normal covering and is very strong.
