ORIGINAL: CRFlyer
An easy way to eliminate the tape, but still seal the gaps is to use an iron on hinge. There used to be a commercial product available, but it is not available any more. However, you can easily make a hinge using fabric covering. This type of hinge is invisible, as it goes under your normal covering and is very strong.
Thanks for the responses guys. I thought I might just be creating an issue out of nothing. I'm glad to see I'm not the only one who thinks the stuff looks terrible. It truly detracts from the look otherwise quality craftsmanship yeilds.
CRFlyer, that sounds like the ideal solution. Do you have any more info regarding this? Might you have pictures, or a rough procedure/material recommendation?
Thanks again!
