RCU Forums - View Single Post - Pull Pull Servo Connections
Old 12-06-2004 | 06:33 PM
Stick Jammer
Default RE: Pull Pull Servo Connections
You should be fine with that set up in your Spitfire. It has small control surfaces and minimal deflection, not a 3D machine by any means. FWIW, those 5945's are way overkill for that application unless you already had them and don't have a better use. Good luck with the Spit. I have the .60 size, great flying bird.
