RCU Forums - View Single Post - Winter Storage ? ?
Old 12-06-2004 | 07:41 PM
**MilkMachine**
Default RE: Winter Storage ? ?
wow, thats an interested picture.
ok but here I know this has been stated several times but lets think of this as a review.
1. ALWAYS CLEAN THE CAR FRONT TO BACK!!!
this is very important, and its also a good way to get too know the assembly of your car. so go through everthing, transmittion, diffs. and even clean of those tires. get it all looking new.
2. PUT IT UP ON BLOCKS
put the car up on blocks for petes sack! man you need this to happen. you can use anything wood blocks books, cd cases, anything but get the car sitting so the wheels are off the ground, this is so the shocks are fully extended!
3. AFTER RUN OIL
take off that glow plug and take off that air filter and push that stuff in the motor so no rust becomes a problem. lubricate that babby. hobbico makes so reliable agter run oil. WD-40 workd great to.
4. REMOE ALL GAS LINES
take them off of the engine. sont go putting them on. expecialy after you after oiled your engine. you dont want some more gas to run in! that would suck.
5. KEEP INSIDE
if you dont have a place in a room or basement then make one. in a cabinet, under the sink, on the shelf in the dining room, in the closet, ect. dont leave the car outside. it is not good for it. the plastic will get brital and begen to crack!
