RE: Ultra Stick LITE Done Right ..!
DP,
Can you describe the construction of you new firewall including how thick you made it? I'd like to go lighter also, but don't trust my design skills in that area yet. Regarding servos, I was using Futuba's which are advertised at 1.3oz, although, I will probably go to a larger torque rating because of the full length ailerons. Regarding mufflers, I'm using the stock G26 muffler, is the Bennett muffler noticeably lighter, if so, I might change that out also.
Chuck
