RCU Forums - View Single Post - transmitter HELP!!!!!
Old 12-07-2004 | 09:06 AM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: transmitter HELP!!!!!
Remember if you decide to mess with the "Expo", go the "negative " side like 10degrees neg or 15 or 20.
If you go the negative side, the the control response seems a bit sloppy until you get to a certain point then it happens. Sort of like making a right turn in your car, your turning the corner and its turning slowing until your wheel gets to a certain point then the car turns very sharp.
If you dial in the positive side of expo, your really "asking for trouble." Again you go to turn the corner in your car and the response is so excessive , the car spins around in circles.
