RCU Forums - View Single Post - :Tip for Rx. padding
Old 12-07-2004 | 10:17 AM
stuk_at_work's Avatar
stuk_at_work
My Feedback: (111)
Default RE: :Tip for Rx. padding
I'm with Bill on the expanding foam issues. It dries fairy rigid and will transmit a lot of vibration to anything "wrapped" in it. As filler or for flotation .. no problem.
Personally, I use Foam Rubber carpet padding as my "replacement" for hobby brands of foam rubber, although I still tend to use it as "filler" with a single layer of Hobby foam rubber directly around my receivers. Too much at stake to gamble here!
