dual ESC's
If I were to use two 7.2 volt ESC's, with one 6 cell battery going to each, and connect the positive output wire of one ESC to the negative output wire to the other ESC, and connect the unused wires of each to the motor, would this give 14.4 volts or the equivalent of 12 cells to the motor, or will it just fry the electronics.
