I'm trying to get online and fly multiplayer, problem is: failed to send player information packet. If anybody knows how to fix that..please post a reply thanks...Rob
This is a known issue related to firewalls. We are working on a fix.
Is there any short cut to changing the airplane direction other than using the airplane spawn.
There is indeed a way to set up the airport so that you can change the airplane's direction with a press of a button. Make two airplane spawns and two pilot spawns. The two plane spawns can be right next to each other, but facing opposite directions. The airplane will start at the spawn point closest to the pilot spawn so make sure that pilot spawn A is closer to plane spawn A, and pilot spawn B is closer to plane spawn B. Then, to change the airplane's direction, just hit 'X'.
