RE: four * performance
WOW!! that is very rapid response!! and very great advice! I like you guy's trim schemes. LarryC, i have seen several planes with a saito 1.00. this looks like the combo I will use. I understand that this is way overkill!! however i want to hover and torque-roll infinitely (and I have seen it done) and the guy told me that if I wanted to pull out with any athority I should go with the Saito 1.00. i understand also that I will not be able to go full throttle on a level run, but i love power in a time of need! I thought of one more upgrade. a bigger rudder. what do you think of this trin scheme? Black on the top, and yellow on the control surfaces and the entire bottom of the wing wrapping around the leading edge? I think this should help greatly with visiblity and also be very good looking.
Thanks very much for all the response so quickly. you guys are great!!!
