RCU Forums - View Single Post - Trim Question
Old 12-07-2004 | 08:35 PM
Diablo-RCU
Default RE: Trim Question
And it can also be trimmed out by adding up thrust to the engine. Adding up thrust will require some down elevator trim under full power. Then when you drop the throttle to idle for the down lines, the engine is not pulling up so that the plane heads straight down. If your plane flies straight up lines and downlines and 45 degree lines upright and inverted ascending and descending, then you've got it licked.
