RE: Breaking in settings
COB, you are going the wrong way brother on the high speed, you want to go clockwise to gain more power. Start over 1. turn the HSN till it just about botoms out (not to tight) 2. open the HSN 3 full turns counter clockwise 3. reset the LSN to two turns out. now Start er up. let it get up to temp this is the third or fourth tank correct. drive it around at these settings not going to full throttle, just yet drive it around slow. Next tank lean it down 1/12 (picture a clock) turn (clockwise) run it around again every once in a while run it past half throttle. next tank repeat but now run it a few passes at afew blips at full throttle. next tank lean once more. lean the low speed 1/12 GO HAVE MAD LST FUN. Be patient 5 or six tanks of fuel are needed for breakin after the initial idle period. after about 10 tanks the mach really makes good power at about 240 degrees. anyone else?
