RE: prop nut comes off
I've had one of my 4 strokers throw a prop once due to being too lean causing a back fire. Crank down on the prop nut enough to get it good and tight, then start with a richer mixture than you have now and reset the engine. I also recommend using a lock nut. It's much safer.
