ORIGINAL: jh
i have the 35mhz dragonfly version and my other 35mhz tx will not work with it so its common across the whole range
Hello JH,
Yes, it's beginning to sound as if the manufacturer has used an incompatible modulation scheme -- probably a cost-saving measure.
I want to use my normal transmitter for the heli so that the control functions will be on the same sticks where I am accustomed to having them. Here in the USA, most of us use Mode 2: aileron and elevator on the right stick, rudder and throttle on the left stick.
Some people have successfully converted the Dragonfly TX from Mode 1 to Mode 2, so that might be my next project.
- Jeff
