RCU Forums - View Single Post - prop nut comes off
Old 12-09-2004 | 04:27 PM
Bayou Talker's Avatar
Bayou Talker
Default RE: prop nut comes off
Before installing the prop nut, add a drop of locktite thread lock to the threads. Use the blue one as it is not as aggressive as the red and will still come off when you need it to. Then tighten the nut securely. This should cure the problem.
