RCU Forums - View Single Post - Mistyer Darby difficulty
Old 12-09-2004 | 07:17 PM
Boulderboater
Default RE: Mistyer Darby difficulty
Hi Pete,
thanks for info. What is CA?
I am considering modifying Mr Darby to make an AT/B combo - so I need to put some rubbing-strake/bump-strip round the waterline, and reshape the nose. I would prefer using wood as it is all curves and easier to work in wood than PVC, etc., After sanding sealer, I have found Krylon spray is quite durable - do you know anything better? How does the epoxy/alcohol mix set up - does it lengthen the curing time, or just make it thinner. Do you have enough time to paint it on, or does it mean there's a lot of sanding needed to shape it?
thanks,
Paul
