RCU Forums - View Single Post - Run my engine for the first time
Old 08-24-2002 | 02:17 PM
TIGER2PLANE
Default Run my engine for the first time
If you prime the motor and it fires but stops, then you are not getting fuel. Look at the fuel tubing to make sure you have fuel to the carb, if you see bubbles then put you finger over the carb intake and turn the prop by HAND till your fuel is in the line, then prime and start motor.
