RCU Forums - View Single Post - BTE Venture 60 build has Commenced!
Old 12-09-2004 | 11:24 PM
Swager
Default RE: BTE Venture 60 build has Commenced!
Well i finished the aft end of the fuselage and the fuel Tank Hatch. It turned out alright. Made the horn hole in the rudder and elevatora nd aligned then. Next is to fine sand and slot the control surfaces. Then..........
Cover!!!
Oh Boy!!
The servo platform in the fuselage only needs one placement for a servo due to I am mounting the rudder and elevator servos aft. The receiver and battery will be secured to this "platform" I wont permentantly secure it until I do a CG test..
Can you tell from the photos which colors I am going with? Also going to add some white!
ID:	201219   Click image for larger version
ID:	201220   Click image for larger version
ID:	201221   Click image for larger version
