RCU Forums - View Single Post - Using Foam Core for Profile Fuselage?
Thread
12-10-2004 | 11:34 AM
1
TLH101
My Feedback: (
90
Dec 2001
6,723
Elephant Butte, N.M.
I posted this in the twin forum to find out if I was nutz, now I am looking for input to see if the contruction method will work.
I have been thinking about a good plane to learn the finer points of twin warbird flight without a large expense. I have a set of Art Johnsons 94" P-38 plans and am considering building the plane as a profile. I could cut the wing cores from foam. The booms and pod would be built from 3/4" pink foam sheeted with 1/8" balsa from the wing back and 1/8" ply forward, with hardwood blocks to handle the engines and gear. Sorta like the old control-line profiles. Maybe just build-up the tail surfaces with sticks and sheet, or just open frame-work. I am thinking a pair of .91 4-strokes and fixed gear with 1/4" wire. Cover the whole thing in iron-on film.
Just as a test, I laminated a 2"x 16" piece of 3/4" pink foam with 2 pieces of 1/8" balsa. I was suprised by just how strong it really is. The first pic is a shot of the laminated part. In the second pic, it has 20lbs of batteries setting on it and it does not bend much at all. I feel this may work real well.
I think I can use 1/8 aircraft ply for the sides on nose of the booms and pod, with hardwood set into the foam to mount the gear and engines to.
Any thoughts?
Reply
Like
TLH101
View Public Profile
Send a private message to TLH101
Find More Posts by TLH101
View iTrader Profile
