RE: help!!! problem with j66hp behotec
Hi,
check if there is enough fuel coming during start up.you can do this by pressing the little button on the ı/o board(the board with the little lamp)..You should here the pump when you press it...if not you have to increase the pump start up voltage...
All above is valid assuming all cables and tubing is correct and leak free...
Rgds
Eray
