RCU Forums - View Single Post - New Plane right one?
Old 12-11-2004 | 05:44 AM
aeajr's Avatar
aeajr
Default RE: New Plane right one?
You ask about this for your first plane, but you indicate you already have a plane.
When you say you flew your Wattage electric several times, is that 10 times or 50 times?
Consistant launch/take-off and landings? Well controlled flights?
There are a several Hobbico Superstar select RTF planes. Are you looking at electric power or glow power?
http://www2.towerhobbies.com/cgi-bin...ct&FVPROFIL=++
Are you learning alone or with an instructor. If you are going glow power, I hope you have an instructor.
The only glow plane that I would suggest for self training is the NextStar as it has a flight stabalization system built in to help you through the early flights. Having said that, I don't recommend anyone go self taught on glow power.
Even with small electrics, your development will go faster with fewer crashes with at least some help.
