RE: New dload for AFP/D Ultiamte Bipe Profile
Your right Joe ... throttle response is the problem.
Do you have a throttle curve in your radio? If so use it! I do and it's perfect. Just set the throttle curve to your liking.
However inverted flat spins work perfect on my sims. Go high, point nose down sticks high and togeter, then slowly move the right stick from high left to high right. keep left stick up and left.
