Of course the real logical answer to this problem would be for the manufacures to put reverse threads on the shaft so when your starting your engine you would be tightening the nut instead of pulling it loose.
Nope. The prop shaft has right hand threads for good reason. The force of a counter clockwise running engine would spin the prop nut off if the threads were left hand.
