RE: prop nut comes off
I guess I am gonna be the minority here. I assume you are using a spinner nut. I have used them almost exclusivly. Never had a problem. Just tighten it up as you would a prop nut. Be sure you are not too lean on the mixture. You should be fine. If you are afraid then a drop or two of blue loctite should do the trick.
Mark Shuman
