RCU Forums - View Single Post - DA 100 Prop advice PLEASE!!!
Old 12-11-2004 | 04:12 PM
DMichael
Default RE: DA 100 Prop advice PLEASE!!!
Scott,
FYI, Hobby Hanger in Chantilly has a 28-10 Mejzlik on the shelf. I have a 25-12 Air Models 3 blade in my shop. Before you buy one, you can try mine. It was only run twice on your engine.
Menz can be purchased from Desert Aircraft or Aircraft International.
RC Showcase is selling the new Bambulas that are very much like the Menz now (new design). Don't know if they have a size right now or not that will work but you could check since they are local. I have a Bam 32-10 on my 160 and it works great. Probably not enough prop now as it rips but so did the Menz 32-10 I had previously. Flight performance is very similar between these two props so I would expect that other sizes would work similarly.
Dave
