RE: Is it possible.
it is possible to change an airplane that was set up to run gas to run on electric instead. you must lighten it if possible to maintain performance. Many gas airplanes are over-strengthened to withstand the loads from a gas engine. the electric engines do not need as much strength around the firewall especially.
