RCU Forums - View Single Post - Sig Extra 300xs questions
Old 12-12-2004 | 10:54 AM
smokingcrater
Default RE: Sig Extra 300xs questions
assuming you just use a Y cable for the battery packs, then they both run in parallel all the time. should a battery pack fail with a broken joint (open circuit) then you will be ok, if one fails with a dead short, that pack will kill the other one also. (fairly rare to fail that way but it can and does happen)
