RE: YOUR Extreme Flight 68" Yak setup?
BosshossV8's Setup Extreme Flight Yak-54 68"
YS 1.10 stock muffler exiting side of cowl.
17x6 APC Imac Aerobatic Prop
Tru Turn 3" spinner
Fuel Dots -filter setup
4.8 v 1650 nimh battery
Futaba 7ch receiver
Hitec 605BBMG servos , Elevators w/reverser Y, Ailerons (Flaperon Ch's 1 & 6)
Dubro Servo arms on above.
Stock hardware used on Ailerons , Elevators, Rudder.
Hitec 645MG Rudder Pull-pull w/ Hitec stock arm.
Futaba 3004 standard on motor box for throttle.
3 1/2" Lite foam wheels (no pants)
Sullivan tail wheel setup
Canopy 2 bolt modification
Re-inforced cowl mounting holes
weight added to right wing for lateral balance
CG: 3/4 " behind spar (extreme Tail heavy)
Fuel : Powermaster 20/20
