By putting washers under the motor mount, I will presume that they meant for you to put them on the two upper firewall mount bolts. That would give your your engine a downward thrust. (Correct me if Im wrong folks). also only use one washer per bolt at a time. You may re- evaluate your CG as well. It may be a tad tail heavy.
