RE: Plane climbs after trim........
Geistware is correct, we need more info. It's typical of most trainers to climb slightly when the throttle is advanced. If your's is climbing constantly no matter what the throttle setting is, then it most likely just needs a little down elevator trim. If it climbs excessively when you advance the throttle, it may have a little too much positive wing incidence or possibly need a little down thrust on the engine.
