RCU Forums - View Single Post - Hot Spot Neutral Position
Old 12-12-2004 | 10:47 PM
Randy M.
My Feedback: (38)
Default RE: Hot Spot Neutral Position
From the manual, ver batem;
In the basic setting for normal flight, the elevons must be up (reflexed) by about 5-7mm, measured at the root trailing edge.
All control surface travels should be measured at the trailing edge. Maximum travels should be 30mm up, 25mm down.
Aileron alone +/- 12 -15mm
Elevator alone 20-25mm up
20-25mm down.
Hope this helps, Randy
