RE: Feedback on TURBINE ENGINES
red
I would check the field that bob suggest and see what is flying and not causing too much grief. There is a bit of a learning curve with each brand of turbine, more specifically ecu, so starting out, it might be handy to get a turbine that someone around you can help with setting up, programming, etc.
