RE: hovering a plane in realflight g2
I assume you mean the Great Planes 330L. It TR's just fine stock. In fact I have flown both the real one and the sim one and they tr similarly. It has small stabs so it has a very small sweat spot. But pull into a perfecly vertical climb, and it will TR without any problems. It doesn't harrier well in the sim so don't try a Harrier entry. You will start your TR Higher, but with practce you can back it down to do tail touches.
I learned to TR on G2 so don't let anyone tell you you can't. I started with the TR cap by Max M something. Very sweat plane. All of Kyle's planes are great for Harriers, and harrier rolls, but a bit too easy to TR.
TRing takes a LOT of stick time, but with the sims you can get a lot of that time done at home.
Rob
