RCU Forums - View Single Post - ailerons-elevators control horns
Old 12-13-2004 | 08:25 AM
Scoubidou's Avatar
Scoubidou
My Feedback: (17)
Default ailerons-elevators control horns
Tom
In the 28% planes manual, you suggest a way that does not allow anything to show on the top surface (ailerons+elevator).
1) My LHS carry only Dubro and Sullivan control horns. May i use Dubro #866 control horns without the black molded washer and replace the 8-32 Allan bolt by a new treaded screw that i am gonna cut to desired length (invisible from the top)?
2) Should i glue the treaded screw into the hardpoint to eliminate any risks of hardware failure from a 50CC engine vibrations?
Is that way as safe as the one with the screw head showing on the top surface?
3) Should i order Rocket city 69D hardware??
Daniel
