RE: Four Stroke Glow To Gas
I'd like to run a Laser 200 V Twin on gas. I guess what I'm most curious about is whether or not the engine would have to be modified mechanically in addition to the ignition changes. For example, is the compression ratio of an engine designed for glow also suitable for gas? Any changes to the combustion chamber? What about seals? Can I use the same carburetor? With or without modification?
