Hi Dion... I got 60 FPS in 32 bit mode however I have a confession[sm=redface.gif]. I removed version 2.5.0 last night and retreated way back to version 2.2.5. The reason is this new upgrade seems to interfere with AFP performance(stutters while flying yet playback is smooth)[sm=thumbdown.gif]. With 2.2.5 I get 30 FPS and no noticeable interference or slowdown while flying or in playback[sm=thumbup.gif]. I have taken every upgrade and keep reverting back to 2.2.5
I think that version 2.2.5 is still available for free download if you are registered. You will not know it is running when flying and the output is excellent. I stay in 32 bit mode with a Radeon 9800 card.
ORIGINAL: STLPilot
Bowser did you install FRAPS? I'm not impressed with the new update. It only gives you the option to select 30-60 FPS however I can get anything above 30 in 8 bit mode.
What are you doing to make it work well?
