RCU Forums - View Single Post - I dropped my Engine! Help??
Old 12-14-2004 | 10:31 AM
Bodge's Avatar
Bodge
Default RE: I dropped my Engine! Help??
Just a thought - You did not say whether you had fitted a prop or not. If a prop was not fitted try fitting one and fully tightenening up the prop nut. This will pull the shaft back through the bearing until it seats and the shaft frees.
I would have thought an OS crank would have survived a small drop like that - even on concrete...
Good luck with it.
Mick.
